Hey everyone.
I am new to Revit. I have created a new document. I tried to draw a wall and a floor. once i draw the lines. I cant see them anymore. unless i go and randomly click in the area then it will be selected. and when i go to 3D view, i see this. See the attached. Any help would be great.
Solved by sabah.al-azzawi. Go to Solution.
verify the View Range from Properties. Perhaps your wall is out of it....
Constantin Stroescu
Actually, i just solved the problem. I tunred out to be under the Graphic Display. I had to change the style to wireframe or realistic.
