How to switch the order of the layers of a wall without changing the dimension,
5 REPLIES 5
JamaL9722060
865 Views, 5 Replies
In the screenshot below, I wanted to switch the order of the layer without changing the dimension. Is that possible?
Thank you
Best
Jamal
Jamal Numan
5 REPLIES 5
LisaDrago
in reply to: JamaL9722060
This depends on the location line (Origin) of the wall as you place it. My Guess the location line is not on the wall center line - maybe the core center line which will give it a bit of an offset.
I have added an image below... when you select the wall in the properties - where is the location line (Origin) of the wall?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
JamaL9722060
in reply to: LisaDrago
Thank for the answer.
Correct. It is drawn with “Finish Face: Exterior” for the “location line”.
But in this case, how to switch the “location line” to be “Wall centerline”?
Jamal Numan
LisaDrago
The wall you have selected - in the properties dialog box - you can change the location line... i
JamaL9722060
Many thanks of the answer. This is very useful. I like your screenshots. My issue is resolved. Sounds to take us a while to get used to the Revit.
Best
Jamal
Jamal Numan
LisaDrago
Yes - screen shots are very useful and I was able to your yours to make it a bit easier.
Revit is not a program to just pick up and yes - there are a lot of little intricate things to work out to make things work the best.
ALso if a solution has been given - can you mark it 'accepted' - only you can do this for the questions you ask. It makes it easier for other to quickly find answers that have worked.
Have a great day!
LD
Rail Community
