I want to subdivide my Revit building model including its components in many segments. These segments will be carried out one after another in the reality. How can I do that without need to subdivide every component (walls, ceilings....) ?
Please provide a better definition of what you mean by "subdividing" the building. That can be interpreted in many different ways. Are you talking about phases? worksets? zones? links? etc....
I have a Revit-Building- Model and I want to divide it in (cast concrete - zones).
It depends how you want to handle this. You could put parameters in your concrete elements, and then filter the views by those parameters, or you could put different elements in different phases. You cannot just "break" big slabs in sectors by those methods, though. For that, you will need to actually edit one slab and create another one.
