How to set the “project units” to be metric in the software?
2 REPLIES 2
JamaL9722060
6329 Views, 2 Replies
I’m wondering if we need each time to set the “project units” manually to be metric. Is there such option to make the “project units” to be metric by default?
Best
Jamal
Jamal Numan
2 REPLIES 2
You need to start with a metric template.  from your other questions about content, it looks like you did not download the metric library when you installed the software.  Here's how to ADD additional content:
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00005-More_Inf0/0138-Installa138/0140-Revit_In140/0...
Scott D Davis
Sr AEC Technical Specialist
thanks for the contribution.
how to start with metric template? is this like the autocad "acadiso.dwt"?
best
Jamal
Jamal Numan
