How to set the “height” of each floor?
10 REPLIES 10
Message 1 of 11
JamaL9722060
26998 Views, 10 Replies
I’m wondering how to set the height of each floor in the Revit to adjust the “height” of the wall accordingly?
Best
Jamal
Jamal Numan
10 REPLIES 10
Message 2 of 11
Click on the text where it says "level 1" or "level 2" on the level line annotations in the elevation view.  The height between the levels will apear in blue text.  Click on the text to change the value.
If you want geometry to move or change with the levels, then you check in the properties of the object to see if there is a relationship.  For instance, with walls, there is a Base Constraint parameter and a Top Constraint parameter.  If the Top Constraint is set to Level 2, then the top of wall will move when level height is changed.
Scott D Davis
Sr AEC Technical Specialist
Message 3 of 11
thank you for the very informative answer.
where the default is set for the height of the floor?
one other issue, how to control the distance between the level sign and the body of the geometry? hw this distance is set bey default?
Jamal Numan
Message 4 of 11
CoreyDaun
in reply to: JamaL9722060
@JamaL9722060 wrote:
"where the default is set for the height of the floor?"
Within the "Out Of The Box" project templates there are two Levels created, the first level at 0' - 0" with the second Level at 10' - 0". (Imperial Templates, of course)
The "default" elevation for the initial level(s) is defined in the Project Template. New Levels are create as needed at whatever height is desired, and drawn in an Elevation Plan with the Level tool. You can learn more about Project Templates >>here<<.
On a side note, it would be beneficial to get accustomed to referring to these as "Levels" in posts, as Floors and Levels are not the same thing.
Message 5 of 11
CoreyDaun
"one other issue, how to control the distance between the level sign and the body of the geometry? hw this distance is set bey default?"
There is no default setting for this distance and it must be adjusted as needed. By selecting the level, a small circle appears at the base of the Level Symbol which acts similar a grip in AutoCAD. (refer to image below). Also note the lock symbol in the image. This indicates that the Level heads are "constrained" and will remain aligned, even if you adjust only one of them. To change one independently, remove the constraint by clicking on the lock icon.
Message 6 of 11
JamaL9722060
in reply to: CoreyDaun
Many thanks for the elaboration. This is helpful. Then all depends on the template we use.
Best
Jamal
Jamal Numan
Message 7 of 11
JamaL9722060
Many thanks for the help,
Then based on what these “levels” are located a distance from the body of the drawing? Does this also belong to the template we use?
Jamal Numan
Message 8 of 11
CoreyDaun
"Then based on what these “levels” are located a distance from the body of the drawing? Does this also belong to the template we use?"
Pretty much every aspect of a project is defined by the template, including the location of and the distance between the Elevation Symbols (as you asked about in another thread). Ideally, one would create a Project Template that includes such preferences and settings as well as any Families that are typically or frequently used.
Message 9 of 11
ccollins
You can use a Scope Box to control the distance that Grids and Levels are away from the model.
Place a Scope Box around your building. Give it a name, or use the default such as Scope Box 1.
Then select all the Grids, and check Scope Box 1. Do the same for Levels.
This way you can control their distances automatically and spend less time dragging them in lots of views,
and spend more time on more important tasks. Smiley Happy
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Message 10 of 11
JamaL9722060
in reply to: ccollins
Your contribution is quite useful. Many thanks
Best
Jamal
Jamal Numan
Message 11 of 11
JamaL9722060
Hi Cliff,
Sorry but I’m again confronting serious problem with the levels
  1. The scope box is created (name SB1) and placed around the building (the screenshot is attached)
  1. The levels are selected and the given the scope box SB1 (attached)
  1. The I got the attached message
The issue here is how the gap between the building and the end of the levels can be controlled (attached)? Scope box/ crop box sounds not to have an effect on that. They have nothing to do in specifying this gab (attached).
How might this be managed?
This issue is also highlighted in the thread below:
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/How-to-avoid-the-overlap-between-the-level...
thank you
best
Jamal
Jamal Numan
