when I open my revit file, I got the following information.
once I close the up diagram, revit diliver the next message.
who can help me to recover my revit file?
Hello and Welcome to the Discussion!
Sorry to see you are having some trouble with your file.
Have you tried an Audit on the file?
In the open dialog box - select the file and in the lower left corner there should be an Audit check box. Select it - you will get a warning that it will take a long time - but it never has... It will check your file for problems and fix them.
Give this a try and let us know if you are able to open the file afterward.
LD
Hello Lisa,
Thanks for your feedback.
Yes, I tried an Audit and Detach from Central before I open the file. Unfortunately, I got this message from Revit.
Crying.......
Jewel
Wow - I am sorry to hear that...
I am thinking you will definately need Autodesk help with that.. I will see what I can do to get someone to assist...
LD
