How to ( Properly ) flip sloped glazing?
2 REPLIES 2
jim5552
5606 Views, 2 Replies
Working on a project with a green house.
I created a roof using "roof by footprint".
I selected "sloped glazing" and assigned mullions for the various conditions as well as spacing.
The walls below are curtain walls.
When I create the roof, the mullions are oriented the wrong way.
How do I control the orientation of the mullions?
In desperation, I mirrored the roof about a vertical axis. See images below.
This corrected the orientation for me, but I must believe there is a better way! A "proper way"...
Did I miss something in the initial creation of the roof?
I changed the sloped glazing of the roof to a basic roof.
When I do this I notice the roof moves up.
I assume this is when the orientation of my roof inverted...
Any insight would be appreciated.
Jim
2 REPLIES 2
Alfredo_Medina
in reply to: jim5552
Select one panel > Edit type > change the value of the offset parameter.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
JensDeSmedt
FYI: This incident is being investigated for a possible cause and resolution.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
