Anyone knows how to program the pattern of a rug (for example, or any other flat object such wall paper) to enlarge or deminish proportionally. Currently I am using Adobe Illustrator to produce the design. 1) How do I convert the pattern created by Illustrator to a file format that is useable in Revit so that I can used the pattern in a space. 2) How can I enlarge or diminish to the size of a space you are creating in Revit if the question 1) is possible.
For Revit a pattern application is accomplished through a material applied to the element. The material can be modified in scale and appearance for how it will be represented when rendered \ displayed in realistic visual style.
I have included some additional resources on how this works, along with how to apply \ edit a material on an element below:
Regarding enlarging a space in Revit, if you are referring to the total physical room this would need to be accomplished through actually moving the wall \ geometry of the space as required.
Thank you,
