I have a Sheet with Building Sections and I would like to show all the sections that are cut throught to have a Poche (i.d., to have a solid hatching or another type of hatching to emphasize the areas that are cut throutht). I want to emphasize the solid walls, slabs, etc., but would also like the lines that are cut throught to show as heavy lines also.
How to do this?
Thanks in advance.
Solved by constantin.stroescu. Go to Solution.
use Detail Level :Coarse
Select object (wall,floor,...) - in Properties > Edit Type>Type Properties > Graphics> Coarse Scale Fill Pattern and Coarse Scale Fill Color - choose the patern and color you want...
Apply : Visual stile > Detail Level :Coarse
Your Name
Thanks, Constantin with the "Poche" issue.
I have another issue with the building section: Some of the trees that are seen in Plan and Building Section when the view is in "Hidden Line" do not show when the view of the Buidling Section is changed to "Realistic". Any ideas why this is happening?
Thanks again.
I suppose you use R2014...and you work with RPC...
You said also that "some o the trees" are not shown when in Visual Style: Realistic .The problem happens only with some of them...
Try this:
If it does not work....then try this:
Your Name
RE The trees. I went to the Edit Family as advised, and looked at some or most to the settings there, but did not see anything there that might be causing this . I am not very knwolegeable with Families, thought.
The heights of these trees that do not show on the elevation when Rendered have been changed from the standard box heihgts.
By the way, these trees that do not show on the elevations when Rendered show OK in 3D Hidden Line of the site plan, but do not show on 3D Rendered of the site plan (the other trees with the heights not changed show OK Rendered on the site plan), and they show on the Floor Plan Rendered with only lines, so I now I think it might be an issue only with "Rendered".
Thanks.
