Revit Architecture
Revit Architecture
JamaL9722060
Message 1 of 3 (269 Views)
How to place the “midpoint” of window on the midpoint of wall?
269 Views, 2 Replies
10-01-2012 02:02 PM
In the screenshot below, I wanted to place the window from its midpoint to the midpoint of the wall. How this can be performed on Revit?
Thank you
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
CADastrophe
Message 2 of 3 (249 Views)
Re: How to place the “midpoint” of window on the midpoint of wall?
10-02-2012 06:20 AM in reply to: JamaL9722060
Place the Window, create a dimension between the faces of the outer walls, and click the "EQ" to make the distances equal. (see image)
You can then remove the dimension afterwards if you wish, and either retain or remove the constraints.
JamaL9722060
Message 3 of 3 (237 Views)
10-02-2012 01:38 PM in reply to: CADastrophe
Many thanks for the answer. I like your screenshot.
I feel that this is very exhaustive. We need to work with dimensions more than working with snaps!
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
