Select the object...
Press the Properties dialogue box button
look for base constraint
you can chose another level
you can also offset it from the level
up or down...down with a negative like -1' 6"
wrote in message news:5121967@discussion.autodesk.com...
i've created a mass element and now i want to move it vertically to a higher
position, but the element moves only horizontally for some reason.
i'm a new user of revit and... well, is there something i can do?
