How to Model a wavy wall in Revit? Please see attached
6 REPLIES 6
Sandra.Massa
4431 Views, 6 Replies
I need to model a wavy wall in Revit.  Please see attached.
Thanks for any advice in advance,
Revit 2014
bluicat
6 REPLIES 6
AJA14
in reply to: Sandra.Massa
1- Use in place family (Not too hard) or in place mass (intermediate)
2- Use adaptive components in conceptual massing (advanced)
Why do you need the waves? If this is just a representation of material, then you can do this with a basic wall.
Hint: Architecture tab - Create - Component - in-place - choose one of the available options and create any form.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
I suggest to use a maped material not to model the 3d...
  1. make a new wall type
  2. make a new material using the bitmap AC_FLOW_WAVE.jpg as generic and bump
  3. adjust the scale of the bitmap
Constantin Stroescu
BIM Manager AGD
Your Name
if I were in the situation to make a real 3d modeling waving surface I'd  rather prefer to do it in 3d max using Displace .
It is also possible to import the resulting 3d object in Revit  exporting from Max into dwg and importing this file into Revit....but it's better to finish it in Max , a program more appropriate for this kind of modeling
in 3DS Max after using Displace modifier:
and imported as dwg into Revit:
Constantin Stroescu
BIM Manager AGD
Your Name
Sandra.Massa
Thanks I will try to do in 3ds Max with Displacement.
Much appreciated,
bluicat
I don't use Revit for rendering, and I only call out and define materials in Revit soley for takeoffs.
Thanks anyway,
bluicat
Sandra.Massa
in reply to: AJA14
I don't use Revit for rendering.  I render in 3ds Max.  So far with all the mapped materials in my procedurals they are not coming out the way that I would like - that's why I want to model it now - hoping for better results.
bluicat
Rail Community
