I want to make a list of all the wall types i have defined in our project-template.
But when i try the schedules i only seem to be able to list those that are "in use"?
Legend view seems totally useless as you cannot tag or list the elements and info like "description" etc. !!??
Any idea is most welcome.
TIA Spacefab
Solved by loboarch. Go to Solution.
All walls defined in the project are listed in the families section of the Project Browser. You could go to that list and right click to "create instance" of each wall and then generate the schedule. There is no way to schedule walls without them actually being IN the project.
Ok...Sounds like a timeconsuming "workaround" though.......
This along with the possibilty to tag properly in legends must go to the "whishlist".
Thanks.
