Welcome to Autodeskā€™s Revit Architecture Forums. Share your knowledge, ask questions, and explore popular Revit Architecture topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
How to hide the Title name under a 3D View on a Title Sheet
2 REPLIES 2
octavio2
566 Views, 2 Replies
How to hide the Title name which appears under a 3D View that is inserted on a Title Sheet?
Thanks in advance.
2 REPLIES 2
L.Maas
in reply to: octavio2
This is part of the viewport. These are also families. So the families you can modify as you like. Often they already have a setting to switch it off.
Louis
Please mention Revit version, especially when uploading Revit files.
octavio2
in reply to: L.Maas
I forgot to took at the "Edit Type" of the Properties Palette.
Thanks, Enlint, for the hint.
Rail Community
