How to hide the Title name which appears under a 3D View that is inserted on a Title Sheet?
Thanks in advance.
Solved by L.Maas. Go to Solution.
This is part of the viewport. These are also families. So the families you can modify as you like. Often they already have a setting to switch it off.
Louis
Please mention Revit version, especially when uploading Revit files.
