HOW TO HIDE LINES
2 REPLIES 2
6757 Views, 2 Replies
HOW TO HIDE LINES
As you will see on the screen cast i need to hide the slab line to show the concrete match with the beam.:http://screencast.com/t/jnjQcWMMdH
2 REPLIES 2
constantin.stroescu
  1. You can solve the problem using : Geometry > Join > Join Geometry. The mandatory condition is to have the same material in elements you want to join (as in real life)
  2. sometimes can be more handy to use an override of the line:select object > View > Linework (LW) > Line Style > Invisible Lines
Constantin Stroescu
thanks very much, the problem is sorted. it works good, now i have a good view of the slab shoing it joined with the beam.
thanks
