Hi! I'm using Revit 2014 & have not been able to fade the ceiling grid lines so they don't plot out so heavy on my dwgs. I've tried overriding graphics of these grids with half tone which didn't work then I tried traspapency & that did not work. They either stay on or turn right off! Any ideas!
Paul
Solved by constantin.stroescu. Go to Solution.
Have you tried to change the material Surface Pattern?
Manage>Materials > Material Browser >Ceiling Tiles >Graphics> Surface Pattern > Color
Your Name
You can also Override (only for active View) .... Why you said you can not?
Your Name
That did it! Thanks Constantine! I originally selected all the ceiling components that right clicked & override graphics by view which was not fading. I followed your steps & everything worked fine.
Thanks again!
Paul
