How to export a schedule from Revit to Excel,
I’m wondering if there is a way to export schedule from Revit to Excel.
Thank you for the help,
Best
Jamal
Solved by Viveka_CD. Go to Solution.
Solved by Alfredo_Medina. Go to Solution.
From the schedule view: Big R > Export > Reports > Schedule. It creates a .txt file that can be opened in Excel.
Many thanks for the help Alfredo_Medina. It works.
Best
Jamal
Hi. i was trying to do the same procedure as oyu mentioned but my "schedule" option is not active. i was wondering if you know the reason.
sorry. i didnt get your point. my problem is shown in below figure. i dont have "schedule" option available here.
many thanks.
Hi.
i have tried different ways to export my model to excell including geometry, sections and .... and modify them in excell and send it back to revit so revit automatically update my mode but i couldnt find a way to do it properly. i was wondering if anyone can help me with that. that would be a great help.
Thank you.
i am tryinng to install DB link on revit 2016. in autodesk help it say " Double-click the AutodeskRevit<version>DBLinkSetup.msi icon" but i couldnt find this icon anywhere. can someone help me with that? thanks in advance
Have you downloaded the installation file from Autodesk Exchange? You have to be a subscriber or have a student/educational account and be logged in to be able to download the file.
You may want to check out on this blog 4 Easy Ways to Link Revit to Excel
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
@amralbarr another similar thread: Best Revit Schedule to Excel Add in
Viveka CD
