How to export a Revit file to dwg in the right scale
1 REPLY 1
melinarch
1007 Views, 1 Reply
Hi, i'm having a really hard time here. I did a whole project in Revit, but now my client wants it in Autocad. Allright, i did everything i should, all the layers are set, but when i export in meters, the scale in the LAYOUT part in autocad is ok, but in the MODEL part is like 1000x bigger. And if i export in milimiters, the opposite happens, the model part is ok, but the layout part, which my sheet is exported the way it should, is 1000x smaller.
PLEEEASE help me.
1 REPLY 1
strange...
have you done these?:
  1. in Revit set the unit for export as Meter: Application Menu > Export > Options >  Export Setup > Units and Coordinates - set to Meter
  2. in AutoCAD  set UNITS to Meter
Constantin Stroescu
BIM Manager AGD
Your Name
