I have a masnry wall with stucco outside and wood furring inside.
When I add the wall footing, the wood furring and gypboard inside go down to the top of the footing.
How can that the furring be stopped at the top of the floor slab so only the masonry is seen below the slab?
Thanks in advance.
Thank you for posting.
You can modify a layer of the wall by follwoing the steps below:
1. Select the wall>Edit Type>Structure
2. In the new dialog box select "preview" and in the view select "Section" to see the wall in section.
3. Click the "Modify" button and select the bottom line of the walll that you want to manipulate.
4. When you see the lock, make sure to unlock the line.
5. Click ok.
In the section view you can now select the layer and move it.
Hope that helps.
