Dear sir or madam,
i have one question about revit, whe i draw line objecct too small like 0.5 it came out error.
the error is "Element is too small on screen".
i try create casement window, so the window profile have a thickness 0.5mm.
i need you advise, i have attach autocad drawing. how to draw this kind object at revit?
Best regarding By,
Marc Law
You are running into the limits of Revit. Revit can not draw lines shorter than approx 0.8 mm.
Normally you will not have to model such small details. If you would model everything in this kind of detail the project would be huge and not manageable anymore.
The normal approach would be to model your window in less detail. In the (drafting) views you would prepare the details.
You can check out youtube to find material on detailing in Revit
Louis
Please mention Revit version, especially when uploading Revit files.
