This is something that used to be very easy to do in autocad (with a polyline) and checking the lenght on the properties bar.
When I select multiple lines (chain of lines) the "lenght" data is greyed out.
I hate having to measure every segment separately! It has to be easier... right?
Solved by rosskirby. Go to Solution.
A dirty, but do-able method would be to create a conduit run, then use a Conduit Run Schedule
(A "Conduit Run" schedule will show a length. This is the ONLY place we've been able to find it.)
The "Solution" doesn't seem to work if the chain of model "lines" contain arcs - at least not for me anyway.
I was attempting to get the perimeter value from a HSS square tube steel column by quickly creating the perimeter model lines.
While I can tab-select the entire chain, once the Measure Along tool is engaged, it will not tab-select beyond the start of the first non-linear connected element in the chain.
Oh well ... now looking for an extension.
it is also possible with a macro
* Created by SharpDevelop.
* User: dbe
* Date: 09-09-2016
* Time: 08:28
* To change this template use Tools | Options | Coding | Edit Standard Headers.
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
namespace lengthofline
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
[Autodesk.Revit.DB.Macros.AddInId("7FFD8872-80F5-4667-867C-E90F88E955DC")]
public partial class ThisApplication
private void Module_Startup(object sender, EventArgs e)
private void Module_Shutdown(object sender, EventArgs e)
#region Revit Macros generated code
private void InternalStartup()
this.Startup += new System.EventHandler(Module_Startup);
this.Shutdown += new System.EventHandler(Module_Shutdown);
#endregion
public void lineLength()
double length = 0;
Document doc = this.ActiveUIDocument.Document;
UIDocument uidoc = this.ActiveUIDocument;
ICollection<ElementId> ids = uidoc.Selection.GetElementIds();
foreach (ElementId id in ids)
Element e = doc.GetElement(id);
Parameter lengthParam = e.get_Parameter(BuiltInParameter.CURVE_ELEM_LENGTH);
if (lengthParam == null)
continue;
length += lengthParam.AsDouble();
string lengthWithUnits = UnitFormatUtils.Format(doc.GetUnits(), UnitType.UT_Length, length, false, false);
TaskDialog.Show("Length", ids.Count + " elements = " + lengthWithUnits);
// public void NewTagMethod()
Regardless of why someone might want to see a total distance of connected detail lines when you TAB+select them, this seems like a very basic reporting function that should already be there.
Revit will currently show any single detail line length if you pick it. Can't Revit add up the connected lengths and show that?
What programmer would think it's OK to have the "Length" box in the properties dialog go blank in that situation?
This doesn't seem like a function that should be at all hard to implement.
Another workaround is draw lines in an in-place mass and use divided path.
Thank you. I understand there are several workarounds for building a path that will report total length. This is not a "feature" that would be added as a cool new thing. It's just a property dialog box that isn't reporting an obvious piece of data. And it's data that Revit already has, since it will tell the length of any single detail line; they just need to add up the lengths of TAB+selected detail lines and show that length in Properties.
We should not need a workaround for that.
I do think they should also add a feature for very easily making egress paths on Egress Plans, as that is a common part of normal documentation, and I've seen some pretty creative workarounds for that.
I agree it should probably be easier to do this, but as far as resolving the "length" on the properties dialog to "null" once more than one line in a chain is selected, it follows the "logic" of Revit.
The properties palette is showing instance properties of the selected element. If more than one element is selected, the properties palette will show instance parameters/values that are common between the selected elements. If you select more than one line, unless they are EXACTLY the same length, the "length" INSTANCE parameter reports a null value. Even if you select multiple lines exactly the same length, the values are not added, the length of the individual lines is reported. The properties palette in Revit is just not capable of reporting "length" in the way you are asking.
The command "Measure Along" will add individual lengths together. It is a different tool. It reports the value in a different location. I am not sure why Measure Along will not work with detail lines or stops once it encounters a non linear segment?
In order to do what you are asking I suspect you would have to totally re-architect the way the properties palette works, or introduce a new element type like a polyline in AutoCAD that could report the total length of the elements making up the "polyline" element.
If it is important to your workflow, I would suggest adding to the Revit Idea Station thread on the subject so the Revit team can understand your needs.
If you use the macro i provided earlier, you end up with a result like the picture below. Maybe Autodesk will make a dedicated button for measuring a line. Maybe you could make a dynamo script.
There is also a last solution. Create a detail item family that will fulfil your needs.
I'm not sure that Revit ever will be as good as Autocad at the 2D part, but I also don’t think that it is meant to be.
I feel the real question here is when is Autodesk going to address the shortcomings of electrical? Reference planes on conduit and duct have been missing since the original release of Revit MEP! I mean seriously, Bottom of Duct is available, but not bottom of cable tray? We're coming up on 5 years now of relatively simple fixes that would help us in the field tremendously. Conduit runs are glitchy, and as we've found, don't fully even work right for conduit run lengths. I ended up building a dynamo script to analyze conduits and bends to calculate a run length to solidify the reporting from Revit, as we had numerous discrepancies of the "Conduit Run" data was lost or blanked out in scheduling.
I wouldn't mind sharing the script, but it requires a couple of custom shared parameters, and line numbers applied to the associated conduit your trying to schedule.
We had some cabling on a project we modeled as "conduit" that was several thousand dollars a foot, so accuracy was of extreme importance. My script was the only way I could sleep at night to know we got the takeoff right.
in Revit2017 i have the bottom and top elevation of a cable tray. And conduit.
Do you measn ín a section?
I drew a line, pressed AL, tabed over the bottom on the cable tray, clicked the mouse.
Now the bottom of the cable tray is aligned with the line.
This works in both fine and medium detail level.
Yeah, sorry, in a section the top and bottom Reference Planes are shut off, or not active. And since you can't modify a system family, the end users can't even fix it.
hi
if you want find the path length for pipe,conduit,cable tray,.etc.. first select the total path after give the required name as a comment in PP ( example: equipment name from to( LDB1 TO MDB )). after create the schedule add comment parameter,length,family and type. here we will got length . but must be select our required path only.
Maybe an updated macro
public void TotalLength()
Selection lines = uidoc.Selection;
ICollection<ElementId> elementIds = lines.GetElementIds();
FilteredElementCollector collector = new FilteredElementCollector(ActiveUIDocument.Document, elementIds);
ElementCategoryFilter filteredElements = new ElementCategoryFilter(BuiltInCategory.OST_Lines);
var elements = collector.WherePasses(filteredElements).ToElements();
double length = 0;
foreach (var e in elements){
Parameter lengthParam = e.LookupParameter("Length");
continue;
var converted = UnitUtils.ConvertFromInternalUnits(length,Autodesk.Revit.DB.DisplayUnitType.DUT_MILLIMETERS);
TaskDialog.Show("TotalLength",converted.ToString());
Lots of creative ideas and workarounds listed in the posts above.
There is another way that seems to work for those who just want to draw some detail lines and measure the combined length. Revit can toggle detail lines to model lines, and change them back again. So just tab+select your chain of detail lines. Click the toggle button (it will appear once the lines are selected) called "Convert Lines". They will all become model lines. Then use the Measure tool -> "Measure along an element" and tab+select the chain of model lines. It reports the total in the upper left corner.
De-select and re-select the chain of lines, and toggle them back to detail lines using "Convert Lines"
If your model isn't flat, some segments may "disappear" from view when changed to model lines. Don't worry, you can still tab+select them as long as a portion is visible, and when you toggle them back to detail lines, they will all appear again.
("Thank you" to a previous contributor who reminded me that Revit will measure a chain of model lines.)
