Revit Architecture
Revit Architecture
Member
lucilarosso
Message 1 of 17 (25,366 Views)
How to determine the total length of multiple lines
25366 Views, 16 Replies
01-18-2012 10:47 AM
This is something that used to be very easy to do in autocad (with a polyline) and checking the lenght on the properties bar.
When I select multiple lines (chain of lines) the "lenght" data is greyed out.
I hate having to measure every segment separately! It has to be easier... right?
It's actually not that hard, even though it sounds a little complicated.  The method I use is shamelessly stolen from Steve Stafford's blog, where he provides the families and schedules you'll need to get the job done.
http://revitoped.blogspot.com/2007/01/egress-path.html
Employee
davissc
Message 2 of 17 (25,356 Views)
Re: How to determine the total length of multiple lines
01-18-2012 11:47 AM in reply to: lucilarosso
use the Measure tool, using measure between two elements, ad check on the Chain option in the Options bar.
Scott D Davis
AEC Technical Specialist
North American Sales
Want Revit Content? Go to http://seek.autodesk.com !
Alfredo_Medina
Message 3 of 17 (25,354 Views)
01-18-2012 11:59 AM in reply to: lucilarosso
Or, maybe faster, without checking Chain, is: Measure > Measure Along an Element. Hover the mouse over the first item, hit the tab key, and click. The result of the total length would be in the options bar.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Member
lucilarosso
Message 4 of 17 (25,344 Views)
01-18-2012 12:25 PM in reply to: Alfredo_Medina
It seems that both solutions involve measuring again everytime the chain of lines are modified. Not ideal to me.
A friend suggested using a spline line with a very tight radius at the corner- it generates an overall lenght on the properties. Seems to be working. Thanks!
Alfredo_Medina
Message 5 of 17 (25,333 Views)
01-18-2012 12:54 PM in reply to: lucilarosso
Not a good advice from your friend. Splines have other issues. Have you tried to use Trim/Extend with splines? You are creating a new set of issues for not doing one extra click with the Measure tool.
rosskirby
Message 6 of 17 (25,320 Views)
01-18-2012 02:03 PM in reply to: lucilarosso
Can you tell us specifically what you're trying to measure?  If it's path of travel, then I'd recommend using a line-based generic model element, and then generating a schedule that stays up-to-date with the total length.  If it's something else, there might be a better way, but it's hard to say without knowing exactly what you're doing.
Ross Kirby
BIM Manager
Arcturis
Member
lucilarosso
Message 7 of 17 (25,311 Views)
01-18-2012 03:08 PM in reply to: lucilarosso
Correct: I am trying to measure a path of travel.
What you are suggesting sounds quite complex ....  Wonder whether I might as well measure every line instead.
But if not too much trouble, I am curious to hear more.
Alfredo_Medina
Message 8 of 17 (25,301 Views)
01-18-2012 08:38 PM in reply to: lucilarosso
Then the proper question to start this thread with was "How to create and measure an egress path?" instead of "How to determine the total length of multiple lines?"
rosskirby
Message 9 of 17 (25,292 Views)
01-19-2012 05:55 AM in reply to: lucilarosso
Ross Kirby
BIM Manager
Arcturis
Member
lucilarosso
Message 10 of 17 (25,285 Views)
01-19-2012 06:45 AM in reply to: rosskirby
Thanks! I'll give it a try.
