How to delete a particular “dimension line”?
4 REPLIES 4
JamaL9722060
5153 Views, 4 Replies
I wanted to delete one of the “dimension lines” but sounds to delete all the connected dimension
Best
Jamal
Jamal Numan
4 REPLIES 4
in reply to: JamaL9722060
you can select that dimension and click on the reference point/element to remove that dimension.
that distance (dimension value) will be added to next dimension.
direct delete is not possible.
JamaL9722060
Thank you for the answer.
For example, in the screenshot below, I wanted to delete the dimension 1.4, but couldn’t know where to click in order to delete it.
Jamal Numan
CoreyDaun
In Revit 2013, you can hover the mouse over a segment of continuous dimensions, press tab to highlight that particular segment, and delete it.
This is not possible in prior releases of Revit.
JamaL9722060
in reply to: CoreyDaun
many thanks. this is much easier.
best
Jamal
Jamal Numan
