How to create a hyperlink in Revit?
4 REPLIES 4
vu.do.mylangroup
18923 Views, 4 Replies
How to create a hyperlink in Revit (hold Ctrl + Mouse Click) to link to another design file or to a spec. component?
Thanks very much
4 REPLIES 4
You can include a web address in an object´s URL parameter, in its type properties window.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
After included the address, how can i open the address with the shorcut key? hold what key with mouse click?
And how can i use dynamic address to insert to this URL?
Thanks very much
It does not work that way. The only way it works is by opening the object's type properties, and clicking on the "..." button next to the URL parameter. If there is an address there, the "..." button will launch your internet browser and take you to that address.
OKArcurrie
in reply to: Alfredo_Medina
I created a Detail Item family as attached and placed and rotated in positions on a floor plan.
I then created panoramic 3D views on Autodesk 360 Render from these points in the model and copied the shared links to these views to a text document.
I printed the plan to PDF and used Adobe Acrobat to add a hyperlink to each symbol, copied and pasted from my text document.
A bit of a work around but the client gets a floor plan with a "click here to view 3D" symbol (with key) which automatically takes them to the panoramic view on their browser.
Cheers
Tags (2)
Rail Community
