Solved by Sahay_R. Go to Solution.
Solved by rudi.roux. Go to Solution.
Hi @werner_aenspeckcordeel_eu,
When you are in a plan view, click on your View Scale Dropdown. After you clicked it, then you add a custom Scale Value 1: 250 (for example).
Hope this helps!
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome ⇘
Please see
Glad to be of help!
Can you mark this as an accepted solution please? Thank you!
How do i customize the scale in the line weight under the setting panel from the manage tab?
Reason being is i'm using 1:300 as it fits nicely onto my titleblock but whenever i export it to dwf, i will have line weight problems. It gets too thick.
related Revit idea: additional custom scale for Revit
@antonjubani - try using Custom.
Custom doesn't allow that ratio. I thought you could "fake" it by making it 2:3 and naming it 1:1.5 but no.
I tried any custom scale to bring drafting view to 1:1.5 but i get an error Enter an integer.
Any other workarouds? i also tried 2:1 still doesn't work. Thanks
Sounds like someones diagram is too big to fit on a sheet.
