how to creat a new Scale (ex: 1=150 & 1=250)
21 REPLIES 21
Message 1 of 22
syria89
21387 Views, 21 Replies
is there a way to creat new customise scale?
21 REPLIES 21
Message 2 of 22
syria89
in reply to: syria89
i found it
scale------customize
Message 3 of 22
syria89
but how to save it to be insited all the time in this template?
Message 4 of 22
melarch
You can create a View Template with a custom scale setting in your Project template and that way when you start a new project the View Template will be available to set any view to that scale, or by selecting multiple views in the project browser you can set them all to the same View Template.
You might try opening your project template and pre setting views to this custom scale.
Mel Persin, AIA
AEC Technology Consultant
Technology to Visualize and Realize Solutions
MasterGraphics, Inc.
Message 5 of 22
Where can I find the 'customize scale' command?
Message 6 of 22
Hi @werner_aenspeckcordeel_eu
When you are in a plan view, click on your View Scale Dropdown. After you clicked it, then you add a custom Scale Value 1:   250 (for example).
Hope this helps! Smiley Happy
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Message 7 of 22
Please see
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 8 of 22
Should have spotted that.
Thanks for the reply!
Message 9 of 22
Glad to be of help!
Can you mark this as an accepted solution please? Thank you!
Rina Sahay
Message 10 of 22
haziqwolly
in reply to: Sahay_R
How do i customize the scale in the line weight under the setting panel from the manage tab?
Reason being is i'm using 1:300 as it fits nicely onto my titleblock but whenever i export it to dwf, i will have line weight problems. It gets too thick.
Tags (2)
Message 11 of 22
lionel.kai
related Revit idea: additional custom scale for Revit
Lionel J. Camara
BIM Manager at KAI Hawaii, Inc. - Structural and Forensic Engineers
Autodesk Certified Professional
Message 12 of 22
antonjubani
in reply to: lionel.kai
Is it possible to create 1:1.5 scale?
Message 13 of 22
RobDraw
No.
Rob
Message 14 of 22
Sahay_R
in reply to: antonjubani
@antonjubani - try using Custom.
Rina Sahay
Message 15 of 22
RobDraw
Custom doesn't allow that ratio. I thought you could "fake" it by making it 2:3 and naming it 1:1.5 but no.
Rob
Message 16 of 22
antonjubani
I tried any custom scale to bring drafting view to 1:1.5 but i get an error Enter an integer.
Any other workarouds? i also tried 2:1 still doesn't work. Thanks
Message 17 of 22
What are you drawing that requires such odd and large scales?
Message 18 of 22
antonjubani
in reply to: ToanDN
... Electrical wiring diagrams.... 🙂 and modules -  🤓
Message 19 of 22
Aren't those supposed to be not to scale? They are diagrams. What purpose is the scale serving?
Message 20 of 22
RobDraw
Sounds like someones diagram is too big to fit on a sheet.
Rob
Rail Community
