How to convert revit drawing file into a pdf format
11 REPLIES 11
Message 1 of 12
43049 Views, 11 Replies
How to convert revit drawing file into a pdf format?
11 REPLIES 11
Message 2 of 12
Use a PDF printer--like Adobe PDF PDF Factory, or PDF 995 ( free ).
Another ( better, IMO ) option is DWFX for Autodesk Design Review ( free download from Adesk ).
This way the person viewing the DWFX can see all the "information" of model elements, and if you create a 3D DWFX
file they can slice/cut sections, spin around, etc. Its a great "free BIM viewer.
cheers
Message 3 of 12
I need information on how to convert revit drawing into a pdf format so that I can print from my PC and printer.
John.
Message 4 of 12
rosskirby
As mentioned above, you will need to install a PDF virtual printer on your computer.  I recommend PDF Creator (link) because it's free and easy to use.  Then you just print your files like you normally would, but choose the PDF printer instead.  It will give you a pop-up window asking where you want to save the PDF, and what you want to name it.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
Message 5 of 12
in reply to: rosskirby
Thanks for the information.
John.
Message 6 of 12
Let me point out that you could have printed out using microsoft XPS writer which is default for windows7 and 8 os. Gud luck
Message 7 of 12
Many thanks for the information.
Cheers,
John.
Message 8 of 12
Hi, John.
I wonder which kind of pdf converter you usually used? Any suggetsion will be appreciated. Thanks in advance.
Best regards,
Pan
Message 9 of 12
rupeshperisetti
How to convert Pdf file into Revit file
Message 10 of 12
in reply to: rupeshperisetti
Print to any PDF printer: PDF Architect, PDF Creator, CutePDF, Adobe
Acrobat...
Message 11 of 12
RDAOU
@rupeshperisetti
A PDF TO RVT!!! Is this a serious question? Like in really CONVERT?!
Message 12 of 12
braeinz
in reply to: RDAOU
https://youtu.be/ta3mrA7WxLc     check out this tutorial video, you may find it helpful too
