How to bridge the gap at the intersection of two types of wall,
2 REPLIES 2
JamaL9722060
350 Views, 2 Replies
I’m wondering which “function” settings are required such that the intersection between two types of all walls (30 cm and 10cm) produce solid line.
Thank you
Best
Jamal
Jamal Numan
2 REPLIES 2
Select the interior wall that intersects the exterior wall.  A blue node will appear at the end of the interior wall where it intersects the exterior wall. Right click the node and select "Dissallow Join".  Now drag the wall back a bit so it alligns with the exterior wall properly.
Many thanks for the answer. This is quite helpful.
Then I need to perform all these steps manually in order to have line at the intersection! Can’t this be performed automatically applying particular function/material settings?
Jamal Numan
Rail Community
