Revit Architecture
Active Contributor
kukuzry
Message 1 of 4 (458 Views)
How to annotate Ellipse?
458 Views, 3 Replies
06-17-2013 12:10 PM
I am creating a family which uses an elliptical extrusion. However, I cannot bind the dimension of the ellipse to the parameters. How can I annotate the dimension of the ellipse? Thanks.!
*Expert Elite*
Alfredo_Medina
Message 2 of 4 (451 Views)
Re: How to annotate Ellipse?
06-17-2013 12:30 PM in reply to: kukuzry
If is not difficult to place dimensions to control the size of the ellipse. For example, if you want to control total width or total height, simply dimension from one blue square dot to the one on the other side. If you need to measure from the center to a quadrant, turn on the center mark, and measure from there to a quadrant. Even the focus points are available if you turn them on, from the Properties window.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Active Contributor
kukuzry
Message 3 of 4 (441 Views)
06-17-2013 12:49 PM in reply to: Alfredo_Medina
I attach the file.  There is a ellipse and  I want to bind the "Width" and "Length" parameters to ellipse width and height.
However, I tried but cannot bind them, could you help me check it why I can not do that ? Thanks,
Active Contributor
kukuzry
Message 4 of 4 (434 Views)
06-17-2013 01:00 PM in reply to: kukuzry
I figure it out. I should edit it in boundary not in extrusion shape....
Post to the Community
New Post
Need installation help?
