How to activate snap tools?
1 REPLY 1
1246 Views, 1 Reply
I've just recently started to try using Revit architecture, most of it seems fairly self explanitory however I've had trouble because I don't know how to get the snap tools (like those found on autocad) to work.
The First situation I want to solve is positioning a steel I-frame column to the center of a pad foundation. However when it comes to moving the column or just trying to create it in the centre no points appear to help me position it?
1 REPLY 1
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/2921-Customiz2921/2931-Project_2...
You should be able to snap to the midpoint of the footing to correctly position the column.
Use the Tab key to cycle thru possible elements when selecting/moving/snapping.
Also, use keyboard shortcuts such as SM for Snap Midpoint, SC for Snap Center, SP for Snap Perpendicular, etc.
