How I recover from unrecoverable error
1 REPLY 1
493 Views, 1 Reply
Hi All,
Just like to share.
This was happened on a Revit 2014 running on Windows 8.
Basically, i can't even open sample project or created a new project, and, the error message popped out right when the document was about to complete the opening or creating of the document.
I created another user account on the same pc, log in and run Revit. It run normally, and everything function and command works properly too.
Then i read the article on clean uninstalling. Instead of removing the Revit application, i did the 'cleaning' parts only.
That is, delete the folder
C:\Users\%username%\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2014
Sadly, the problem persists.
Lastly, i deleted the registry key HKEY_CURRENT_USER\Software\Autodesk\Revit\Autodesk Revit 2014.
No more unrecoverable error! No uninstall and re-installation.
I believe this shortcut only works on corrupted user profile. This is my 2 cents.
Cheers.
Koh Kah Chin
ps. do forgive my bad English.
1 REPLY 1
I found that by uninstalling Revit 2013 and then updating windows (through control panel - update centre), then restarting and reinstalling Revit, Revit would then work.
Hope this helps. I tried everything else that was suggested but a reinstall and update worked for me.
