I'm doing as-builts of a historic structure and the walls are very slightly out of alignment with the x-y axes. Whenever I'm drawing something that's nearly (but not quite) horizontal or vertical, Revit forces it to be aligned to x-y axes. I don't want that but don't know how to turn it off so that it snaps only to my crooked geometry.
Thanks for any help!
The only way I know of would be to check the Snaps Off check box in the Snaps dialog box or SO keyboard short cut.
Otherwise the ortho is locked on.
LD
Try to uncheck :Angular Dimension Snap Increments from Manage>Snaps
Constantin Stroescu
