How do I turn off orthogonal snapping?
4 REPLIES 4
46462 Views, 4 Replies
I'm doing as-builts of a historic structure and the walls are very slightly out of alignment with the x-y axes. Whenever I'm drawing something that's nearly (but not quite) horizontal or vertical, Revit forces it to be aligned to x-y axes. I don't want that but don't know how to turn it off so that it snaps only to my crooked geometry.
Thanks for any help!
4 REPLIES 4
LisaDrago
The only way I know of would be to check the Snaps Off check box in the Snaps dialog box or SO keyboard short cut.
Otherwise the ortho is locked on.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
constantin.stroescu
Try to uncheck :Angular Dimension Snap Increments from Manage>Snaps
Constantin Stroescu
in reply to: constantin.stroescu
I worked it out. I have to hold down the SHIFT, then TAB through my snaps.
James Negri, Digital Artist | Associate
Hanbury Evans Wright Vlattas + Company | Architecture Planning | www.hewv.com
120 Atlantic Street, Norfolk, VA 23510| t: 757.321.9656 f: 757.321.9601
This might help.
Tick off constrain when you use the Move tool
Tags (1)
