This and other elevations have lines between new and existing walls/soffits. Joining doesn't eliminate the line. The existing wall is also in a group.
Is there any way to selectively hide an edge in an elevation?
AutoCAD 2010
AutoCAD 2015
Revit 2015
Solved by constantin.stroescu. Go to Solution.
First ,you must be sure that the surface are trully aligned ( use Align tool - I do it in a 3d View) and the material from finishes is the same one.
If this does not work you can use , in Elevation View or in any other view , Linework Override :
Thanks. Typing LW makes a quick shorthand to get to it quickly.
AutoCAD 2010
AutoCAD 2015
Revit 2015
