How do I edit view titles?
3 REPLIES 3
NigelParsons4560
8508 Views, 3 Replies
I don't like the way View Titles look on sheets, so I turn them off under Visibility/Graphics and use plain annotation text.  Is there a way to configure these?  I can't seem to activate them.
3 REPLIES 3
is this what you what?
If you browse to library> annotation folder, you will see several Revit view title families.
view_title_family
It means you can modify the geometry and text to control the view title appearance.
Try to load another view title family to your project. Now open your sheet, select the viewport.
Click edit type to open type properties dialog box. Now you can see the view title family on title drop down list.
changing_Revit_view_title_type
mrtom8361
in reply to: ennujozlagam
Why does my folder not contain the view title families?
ennujozlagam
in reply to: mrtom8361
hello, it could be your libraries and templates are not installed properly. thanks
