I don't like the way View Titles look on sheets, so I turn them off under Visibility/Graphics and use plain annotation text. Is there a way to configure these? I can't seem to activate them.
Solved by ennujozlagam. Go to Solution.
is this what you what?
If you browse to library> annotation folder, you will see several Revit view title families.
It means you can modify the geometry and text to control the view title appearance.
Try to load another view title family to your project. Now open your sheet, select the viewport.
Click edit type to open type properties dialog box. Now you can see the view title family on title drop down list.
hello, it could be your libraries and templates are not installed properly. thanks
