Go to Project Browser/Families/Profiles, then right click on the main stream of the profile you want to change, hit Edit
13 years after the original post, I suspect the person posting has figured it out or moved on.
His answer just helped me solve my problem where the question was never properly resolved. Perhaps you should reconsider your replies to helpful responses.
Thank you SepMova, great answer.
The first answer only shows you how to modify a profile parameter, the new answer shows you how to actually Edit the profile. No need to go look for an external file, maybe it used to be the case, but not in Revit 2017 anyway.
Necro-thread, but helpful nonetheless.
Version 2021.1.2, there is no edit when I right click on the profile. So how do you find where the file is to open it to edit it? If it is in a model we downloaded from some where on the internet are we screwed? I would think the profile file is somewhere in the model.
There is no edit. Why is editing a simple profile such a difficult task?!!?
Cannot edit profile!!! Why is this not easier?!!
You can see the Profile Type assigned to the Slab Edge Type via the Slab Edge Type properties. Now look in the Browser > Families > Profiles > select the profile family with that type name and edit its parameters or open it to edit.
