How do I create a mass that is a loft to a point?
2 REPLIES 2
388 Views, 2 Replies
How do I create a form in the massing tools that is a lofted profile to a point?
Tags (2)
2 REPLIES 2
scott_d_davis
Easy way:
Make the "point" a very small profile, such as a 1mm square, which will be smaller than can actually be built.  Will be a solid.
Harder way:
make individual faces built of profiles of the "sides" of the object.  Won't be a solid.
More involved:
make a solid, then carve away with voids to form the "pointed" object.
Scott D Davis
Sr AEC Technical Specialist
Actually, Revit can go as far as 0.2 millimeters of distance between 2 or more points, to have a mass or surface end at "a point". For further reading about this, please refer to this thread in Revitforum:
http://www.revitforum.org/architecture-conceptual-massing-adaptive-components/21274-there-way-schedu...
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
