Hi Sir,
I am working on the Fire-resistance rating for the walls. I am trying to find out the "Type Mark" value for walls.
Please explain me how can i get "Type Mark" value, also i need details information for "Type Mark" value.
Please help me.
Thanks in advance.
Nitin.
The type mark is a type property that you fill up in the type properties of walls. You also have one called mark in the identity data of the instance properties. You can acquire this information directly in your schedule when you go to schedules in the view ribbon and choose the wall category.
Regards.
Actually what i want is the coding part.
Methods i am using currently is:
Parameter parm = temWall.get_Parameter(BuiltInParameter.ALL_MODEL_MARK);
string typeparameter = GetProperty(temWall, BuiltInParameter.ALL_MODEL_TYPE_MARK);
But unable to get the "Type Mark(A1, A2, B1 ....... etc)" for the wall.
Need help! Help me!
Nitin Kumar.
You need to be specific from the beginning of the thread. How could anybody guess that you were referring to programming code?
