Hi every one I explained my question by the picture which I will attach.But ı am explaining the issue briefly.I want to create 2 pads(one of has slope) which share a boundary.But it doesn't work as I wan't. I have explained in the picture. Thank you.
I would suggest this video showing the worklow in the creation of slopped building pads, and then edit the surface perimeter.
Good Luck
Luis
I have already tried what explained in the video but my case is different.In the video I explained it in detail
Thank you very much it solved one of my big problems which is bleeding problem.However I have one more.In the link he mentioned two pad which share straight line shaped edge together.It is simple two get these two pads at same elevation at these shared edge.However in my case pads share a curved shaped boundary(as ı show in picture I attached at the begining) so I can not get the pads at same elevation at these curved shaped boundary by slope arrow.Thank you again...
