I've downloaded BIM Door Families from Kawneer and would like to simplify the file to cut down on data size. I enter into 'Edit Sweep" and select the profile, but it gives me the option to select a profile designed by them or draw my own. I would draw my own, however the faded lines showing the existing conditions vanish and I am unable to trace the profile.
Is there a way to open the profile file and edit it? If so were should I look for it?
If not, what other methods could i use to simplify this family?
Thanks!
you can edit the profile this way...
pick edit. but you might want to save the profile out as a different name, reload it, then modify it in case you need the original for some reason.
Mr. David is stated absolutely correct. This is the process to edit or create a new profile with existing profile. Try with this.
Thanks & regards,
Subhradeep Sen
Kolkata
India
