I am trying to figure out how to change the font size on room tags. Can anyone help?
Thanks in advance.
Solved by Sahay_R. Go to Solution.
Solved by constantin.stroescu. Go to Solution.
Solved by KevinMAX. Go to Solution.
Constantin Stroescu
Now I can get a smaller room tag to fit in small rooms, such as closets, but the original large size frame around the room number is still there. How can that be resized and/or erased?
The same you way you changed the font size, edit the family and change the frame. Frames are regular lines.
I usually have two frame sizes controlled by the visibility parameter in two family types .
Gustavo
Thanks for responding. In Edit Family mode, the room number frame changes. But after I save under another name, load into the project, the original frame size doesn’t change. Maybe I missed something. Could you please provide details?
Just to clarify:
-The text is reduced but the frame don´t?
-After you load the new tag family you replace the tag used in the project with the new one and the frame size stays the same?
Only things i can think of are you forget to change the tags after loading the new family or you are trying on a view with a different scale so tag looks bigger.
Gustavo
That is correct. It's probably a scale problem: tag (frame) and text are not in the same scale. I don’t see a way to go to tag’s properties to change parameters or erase it completely.
I was talking about different views with different scales. Text and frame couldn't have different scales belonging to the same family. By the way, tags doesn´t have a scale, they are annotation, this means they allways have the same size no matter what's the scale of the view.
Could you attach your tag family here? What version are you using?
Gustavo
I've made a recording on the Frame subject.
https://screencast.autodesk.com/main/details/71961460-9f82-4163-9a9e-b3a56df8ec7b
Constantin Stroescu
Can't see the attachment Kevin. But i think Constantin already did a good job with his video.
Gustavo
Thanks a lot, Constantin,
Your video tutorial was great. I fixed my problem and learned more about room tag customization. Again, much appreciation for your time and patience.
Steps would still be the same.
I am having the same issues with the room number "border" not changing in the project. I have modified every border aspect possible in the family editor and the border around the room number is still huge. See screen shot below.
Remove the border around the room number entirely. Edit the label type so that the text has a border - all you need to do is check a checkbox. The number will appear with a box that flexes with the number of digits.
