Anybody knows how I can place a horizontal section mark that is linked to a callout detail. Whenever I draw shop drawing of windows and door for instance, I need to place horizontal section marks that are linked to the plan view detail callouts. Any suggestions?
Solved by FinearcLtd. Go to Solution.
Solved by Alisder.Brown. Go to Solution.
Thank you for your suggestion. I don't see how this solves my problem of nested detail items in families. Can I really make a level tag that, like a callout, is linked to a sheet? If not I cannot really use it for that purpse. Creating plan views is not the same as creating callouts they are not the same family of views and therefore can be confusing and not in line with systematic orderly workflow.
Correct me if I am wrong...
Hey
In your elevation view, click the section button, but before you draw the section line, change the type to a "detail view" from the type selector. This allows you to draw horizontal sections with the view/sheet refrence head 🙂
Hope this helps
I'm in an elevation view. I tried clicking the section button, and then changing the type to a "detail view". When I draw the horizontal section, it disappears and I get that message:
"None of the created elements are visible in Elevation: 104-E View. You may want to check the active view, its Parameters, and Visibility settings."
Even with everything turned on in the VG settings, nothing shows up.
What am I missing?
Figured it out. Sections was turned on in VG settings, but there was a filter applied that turned off all sections but my casework sections
Hey
I have a question relating this subject, this indeed works for horizontal sections. But when you want to make a horizontal section that looks up, the view you get is a mirrored view. Ideas of how to solve this issue?
Thanks in advance.
Hi, I was more or less in the same situation as you. I solved it by doing the following: created the horizontal section; changed the "flip section" to be upwards (look up). Then since the view was mirrored compared to the orientation of the views looking down, I got into the view, selected the crop region and then rotated 180°.
