Historic Revit 2013
22 REPLIES 22
Message 1 of 23
vector2
739 Views, 22 Replies
Historic Revit 2013
The day finally comes, BIM is airborne. It's called "Autodesk Revit 2013". Architecture, Structure and Systems all in one. Congratulations Autodesk.
22 REPLIES 22
Message 21 of 23
cvandevere
in reply to: vector2
I am guessing you have downloaded the trial version which has all three combined. If I understand what autodesk is doing however if you have a standalone version and are on subscription you will be only eligible for the standalone  version. If you want the combined version you will have to upgrade to one of the suites. http://usa.autodesk.com/revit/how-to-buy/
CDV
Message 22 of 23
vector2
in reply to: cvandevere
"I am guessing you have downloaded the trial version"
The trial version is the whole version. You just cut Autodesk a check, (if you
are not on subscription), so you can print and save beyond 30 days.
IF- you want to buy it.
Edit:    Actually, when you buy a license for Revit, all you're doing is having
them unlock the print and save on a trial version.
But everything about the process is fair and square in my mind.
Message 23 of 23
DarrenP
@vector2
that explains a lot
i didn't know the revit trial was being offered that way
DarrenP
