suggest you not use worksets as a visibility control. Use filters, as that
is what they are intended to do.
"mjohnson" wrote in message
news:5483329@discussion.autodesk.com...
If you use worksets, put the finish floor on a separate workset that can be
turned off as needed. Filters would also work.
-MJ
wrote in message news:5483076@discussion.autodesk.com...
Hi its Nathalie here
I am trying to do slab plans and floor framing plans. I have drawn the
floors with the normal slab and then created another floor on top to show
floor coverings. When i go to do the slab plan, i cant turn the floor
coverings off because they are in the same family as the slab (that i want
to keep)
Does any know how i can turn off just the floor coverings?
Any suggestions would be great!!!
