Hiding Floors without using Hide/isolate
5 REPLIES 5
Nathalie
230 Views, 5 Replies
Hi its Nathalie here
I am trying to do slab plans and floor framing plans. I have drawn the floors with the normal slab and then created another floor on top to show floor coverings. When i go to do the slab plan, i cant turn the floor coverings off because they are in the same family as the slab (that i want to keep)
Does any know how i can turn off just the floor coverings?
Any suggestions would be great!!!
5 REPLIES 5
in reply to: Nathalie
try using visibility settings......
right click in view properties,visibility,untick the surface pattern in the floors
RevitIt
Use filter to control visibility
If you use worksets, put the finish floor on a separate workset that can be
turned off as needed. Filters would also work.
-MJ
wrote in message news:5483076@discussion.autodesk.com...
to keep)
suggest you not use worksets as a visibility control. Use filters, as that
is what they are intended to do.
"mjohnson" wrote in message
news:5483329@discussion.autodesk.com...
-MJ
to keep)
Nathalie
Thanks i will try your suggestions.
