I have created my model, and have placed the floor assembly in. It is concrete and I see the concrete pattern on the floor. How do I hide or turn that off? I cannot find anything in Visibility Graphics or in the actual floor family...
Thanks...
-Frustrated (Dave)
Under Floor Model Category in VG, click Override Pattern, then turn off pattern display.
See attached.
cheers
Create a View Filter that applies to the Floors Category, set the Filter Rules to "Type Name" "Contains" "concrete" (assuming that "concrete" appears in the Floor Type's name), add this View Filter to your View(s), and turn off the Surface Pattern display in the same way as described in post #2 above (except in the 'Filters' tab).
You can also right click on the element (Concrete floor) and make sure you have selected "Make the elements editable" . Then right click and go to "Override Graphics in View" > By Elements . On View-Specific Element Graphics > Surface Patterns> Uncheck Visible.
Good Luck,
Cut and projection section under floors. make sure all patterns are turned to not visible.
