In an exercise I did right click on a wall and choosed ( hide in view) to work inside the building. Now I want to get the wall back. I can not select it and then right click to reverse the hiding command, because the wall is invisible. What can I do to get the wall back?
Jaf
Solved by kfielding. Go to Solution.
Solved by ccollins. Go to Solution.
Use the "lightbulb" tool at the bottom of the screen. This will show all hidden elements, and they will appear as a red-purple color. Find your hidden wall, highlight it, then at top of screen choose "unhide hidden element".
Jaf,
If you like keyboard shortcuts the command is RH to reveal Hidden Elements. Select the element to unhide and press UE to Unhide Element.
K
