[ Hide in View] issue?
3 REPLIES 3
jz4all
328 Views, 3 Replies
In an exercise I did right click on a wall and choosed ( hide in view) to work inside the building. Now I want to get the wall back. I can not select it and then right click to reverse the hiding command, because the wall is invisible. What can I do to get the wall back?
Jaf
3 REPLIES 3
in reply to: jz4all
Use the "lightbulb" tool at the bottom of the screen. This will show all hidden elements, and they will appear as a red-purple color. Find your hidden wall, highlight it, then at top of screen choose "unhide hidden element".
in reply to: jz4all
Jaf,
If you like keyboard shortcuts the command is RH to reveal Hidden Elements.  Select the element to unhide and press UE to Unhide Element.
K
jz4all
in reply to: jz4all
Thanks it works perfect.
Jaf
